Turbo cam good for N/A too?
Old Nov 24, 2006 | 02:58 AM
thunder550's Avatar
High on diesel fumes
Default Turbo cam good for N/A too?
May go ahead and get the cam now since the Trucker is going to be small for the 408. I was looking at the cam that TurboBerserker has in his sig, 236/230 on a 115 lsa, I dunno what lift it is, I think somewhere around .600. Will a good turbo cam work well on my temporary N/A setup too? I would imagine it would be better than the 216/224 that I was planning on using.
Old Nov 25, 2006 | 02:52 AM
thunder550's Avatar
Anyone?
Old Nov 25, 2006 | 03:44 AM
Mr. Sandog's Avatar
What are you future plans? Turbo?
Old Nov 25, 2006 | 08:09 AM
fullthrottledan's Avatar
Ive driven my truck with no boost and my turbo cam is fine. I Drove it for about 300ish miles before turbo went on.(my cam is smaller than yours at 226,222)
Old Nov 25, 2006 | 08:34 AM
BigTex's Avatar
Yeah, there are lots of reverse split cams that people run NA. It shouldn't be a problem to run that cam NA for a while. You going to have headers and good exhaust? That will help out with that cam.
Old Nov 25, 2006 | 09:00 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Yeah, it will work fine for a temp NA cam. It is at .60x/.600 on lift.
Old Nov 25, 2006 | 09:41 AM
TurboGibbs's Avatar
Why not. That is exactly what I would do to save on doing the cam swap later.
Old Nov 25, 2006 | 10:29 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
And put your damn heads on too now so all you got to do is put the turbo on, unless you like working on your turck
Old Nov 25, 2006 | 10:32 AM
thunder550's Avatar
Ok ok I'm gonna do it all now. TurboBerserker - where did you get that cam? MFG and model? Have you been happy with it?
Yes for turbo in the future - about 15 psi probably.
I have Pacesetter LT's and ORY planned for exhaust mated to a Corsa cat-back. I think I'll be good for exhaust.
And yes Cody, I'm going to do heads now too Happy??
Old Nov 25, 2006 | 10:39 AM
1slow01Z71's Avatar
I dont know about you man, but Im about tired of working on my **** and Im sure you are too. Heads swaps in the truck are just a major PITA, I know you know what you are getting into, good luck.
Looks like we may have a battle for the fastest ecsb Z71 shortly
