which turbo cam
Got an 01 gmc Z71 with a 6.0. Going to turbo it in the next few Weeks and need to which cam is best for me. Have ls7 lifters ls6 oil pump and going to p&p the heads myself. That's all right now. Use the truck only on the weekends to pull my 4500lb boat but I love to get in the gas when its not behind me tho. So I reckon Priority would be towing and second priority would be speed. Want something driveable. If y'all recommend a custom cam who do you recommend talking too. Thanks!
I've got one that's never been used and it's for sale . . .
https://www.performancetrucks.net/fo...-116-a-522560/
Keep your duration small. This will help tremendously in low end torque for pulling a boat.
I would suggest a 224R on a 112. Not only will this make good low end torque in a 6.0, it will also have 0* of overlap and not bleed off boost in the cylinder.
triple 12 would be good, Stock48 ran one in his 6.0 and also ran or does run a 214/214 I believe.
I have the triple 12 and I made 300whp/310wtq NA in my 5.3. Figure adding 10psi should add around 160rwhp or so, that would be pretty nice even out of a 6.0.
