Turbo build tune questions
Old Oct 15, 2015 | 02:08 PM
  #41
Silveraydo's Avatar
Originally Posted by Show-n-go5.3
FYI When u mount the Map sensor, mount it as close to the intake plenum as possible (on it is best).
The MAP sensor I'm getting will be direct factory replacement so it should work great. Thanks for the info. Anything else I need for speed density? Iat, new 2.5 bar map, wideband (not sure what all I need to hook up for closed loop or if it's just for me). What do I need to do with my pcm if anything? If I'm using Nelson Performance I guess they handle all of that? I'm calling them in a bit
Old Oct 15, 2015 | 09:40 PM
  #42
montecarloss's Avatar
LS ADDICT/BUILDER
Originally Posted by GMCtrk
Tune it yourself would be my recommendation.
X2
If you want your stuff done right and not have your stuff blown up
Old Oct 16, 2015 | 01:41 PM
  #43
kbracing96's Avatar
You'll still need your stock o2's for closed loop. It uses them for normal driving once warmed up. Then goes open loop when your in boost.
flatblack83
Oct 8, 2015 08:29 AM
custm2500
Aug 22, 2015 11:46 PM
signguy62
Aug 18, 2015 09:04 PM
BlackGMC
Aug 18, 2015 01:11 PM
ntxf
Aug 10, 2015 10:12 PM
