Turbo build pics....Finally!
Old May 22, 2006 | 01:00 AM
MrXerox's Avatar
Looks good... You might want to take that AC line down to your local hose or AC parts shop and get them to lengthen it to 2 feet in length and put different angle bends on either end so that it lays to the other side (over motor) Just did this to mine and it only ran me $50.00
Old May 22, 2006 | 01:56 AM
TurboGibbs's Avatar
I may have to look into that. It is working fine like it is. i had to bend the line up and away to get it to clear. There is ~2" of clearence from the downpipe. I plan on having the piping coated in the future. That will help the heat xfer issue against the a/c line a little.
Old May 22, 2006 | 05:48 AM
bud8fan's Avatar
thats great ...i love it ...cant wait for my '93 rcsb front mount 6.0 w/ 80e to get ready as well...bet you cant wait to get it back out there in street form.....
Old May 22, 2006 | 06:59 AM
CurtD's Avatar
10 Second Truck Club
Looks good Mark, I like how you got the IC hidden. I would kinda like mine behind the grille. You talk with Gomer yet about going to the dyno? I need to get mine over there and do some adjusting...and blow the soot out of it
Old May 22, 2006 | 08:12 AM
TurboGibbs's Avatar
Thanks. It idles like stock as well.
No, haven't talked to him yet. I am working the next two weekends coming up. I will be off during the week though. I'll hollar at you when I get ready to go.
Old May 22, 2006 | 06:01 PM
greentahoe's Avatar
Man that is just incredible looking. I cant believe you got it done so quickly!!! So all you did was switch to the complete car intake and fuel rails to what year F body?? Other than cutting the water neck... anything else needed? It does look alot better!
Old May 22, 2006 | 06:10 PM
parish8's Avatar
single digit dreamer
that thing has the potential to make some crazy numbers on the dyno. 2wd, stick, gts76... cant wait to see how it does.
Old May 22, 2006 | 07:31 PM
hemifever's Avatar
Nice work dude!
Old May 22, 2006 | 07:45 PM
TIM Z's Avatar
11 sec. Truck Mod
f n sweet dude !!!! that engine looks bad *** !!!!
Old May 22, 2006 | 07:49 PM
TurboGibbs's Avatar
I appreciate the kudos guys. It has been running for a couple of weeks now. I had 2 weeks off work in which I set the engine in and did all the fab work. Spent a few days waiting on parts. The LS1 intake swap and T56 mods took several days themselves. I had to have the driveshaft shortened 2-3/4" and the crossmemeber required no modifications at all. As for the intake swap I bought the idler bracket from Speartec and copied thier water pump mods. I'd recommend using a car water pump and spacing the pulley out to get it to work rather than the water neck mods on the truck water pump like I did.
The returnless fuel system and the voltage booster is going to be a MFer to tune. I may do a returnless set-up before I go any further. The voltage booster comes in @5psi and if you are not @ wot when there then it looks like a diesel behind me and just floods it. My PE graph looks like a damn Tsunami wave when trying to compensate for the added fuel when you hit 5psi boost
