Turbo 5.3 and a 4l60E?
Old Sep 27, 2005 | 04:47 PM
Steve88's Avatar
Default Turbo 5.3 and a 4l60E?
I have an 02 GMC ECSB Z71 and I am planning to add a turbo set up shortly. I am thinking of going with CMotorsports setup with a t-66 turbo. I take good care of my stuff but I a willing to push it pretty hard so my question is will a 4L60E be able to do the trick or should I just go to a 4l80E. My buddy is a transmission builder and I don't mind adding the required hard parts to the 4l60 but will it be dependable after that. I would prefer to stay with the 4l60 but I will upgrade if it doens't appear that I can get a dependable performance out of the 4l60. Thanks for help
Steve
Old Sep 27, 2005 | 10:43 PM
Eventually no matter what you do, the 60 will break. Of course, if you never get on it and are conservative with your set up, then you would be fine. For most people here, that is not the case. I and most people here will tell you to go with the 80. Good luck!
Old Sep 27, 2005 | 10:50 PM
quicksilverado's Avatar
Even if the 60e holds up the clutches will not last very long.
Old Sep 27, 2005 | 11:51 PM
CAMMIN03''s Avatar
Banned
Ive had my 4l60e in my truck for around 88000 miles, I had a shiftkit and servos put in around 75000 miles...
Its been Sprayed and Superchargerd and its still shifting like new!!!
Im aobut to put a turbo on it, so well see after that!
Old Sep 28, 2005 | 01:46 PM
zippy's Avatar
you need to check out how much power the SS Silverado guys are putting through their 65E's. there is no reason a 5.3L with a turbo can't run a 60E with a few mods.
Old Sep 29, 2005 | 01:54 PM
I have a built 4L60e with 5,000 miles on it and the sts turbo @ 7lbs and still like new.
Old Sep 29, 2005 | 02:39 PM
14 Second Truck Club
Stock-no. But with some minor mods it should hold pretty well. My 60e only lasted a week with my D1, but with the kit and servo's it is still holding.
Choda
Jan 22, 2026 02:03 PM
Jakejack
Jan 8, 2024 10:44 PM
XL7
May 5, 2022 01:48 PM
Jake99
Aug 8, 2015 07:56 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
