Tuning
Yes, you would want to get it re-tuned/checked over.
A larger turbo is going to move more air at any given time so at least watching data logs should be done to see what may need touch ups.
What are you asking though?
The stock 4L60e with stock converter is weak, I'm sure you know that already. A built transmission with a stall that matches the camshaft is always going to be better. Doing that change would need tuning as well.
Or most just 4L80e swap to be done with it, because it's much stronger and a stock 4L80e is super tough and costs way less than a really well built 4L60e. There can be added costs with the swap if you need a new driveshaft made or want to have a higher stall converter or swapping rear end gears to better match the transmission/tire choice.
Mean Green z28
Mar 24, 2017 02:54 PM
sleeperlqx
Mar 30, 2013 01:09 PM
JohnHF
Jan 12, 2011 07:06 AM
