Trying to understand cam overlap and boost
Old May 11, 2012 | 07:03 AM
  #21
03sierraslt's Avatar
I wouldn't get too crazy, your truck is heavy and with a procharger you want low end. I would go with something that has a 12 degree or so exhaust bias. I would also keep my intake duration around 218-220 to help bottom end. You already said you don't plan to spin to 6900 anymore so no sense getting a big cam to spin high rpm if you don't have too. Keep good bottom, and keep your low end response. As for lobes, that depends on what you want. I would keep overlap in the -8 to -2 area at .050. I would also do a 114/115 LSA with a +2 advance
Again all just my opinion.
Old May 11, 2012 | 08:41 AM
  #22
ak2007r6's Avatar
Originally Posted by AKlowriderZ71
Datalog your IDC% at the shift points first. IIRC, I set your shift points based on IDC at 11.5 AFR. Those 65#'ers are maxxed out.
Yea I was planning on logging it at the track when I get home to see how they are doing. Maybe next year we can do the ARP treatment to the motor and pulley it down a little and get some bigger injectors
Boost is addicting
Old May 11, 2012 | 08:46 AM
  #23
AndysC3's Avatar
Is procharger the only ones that can upgrade a p1sc to a d1sc? I thought I saw somewhere that house of boost can do it cheaper.
Old May 11, 2012 | 08:47 PM
  #24
That I do not know, where are all the procharger guys at? For some reason I am thinking other places can do it also but I could be wrong.
2500ZL1
Jan 25, 2016 06:30 AM
greedygenius
Sep 3, 2015 06:51 AM
JordanH
Aug 8, 2015 07:59 PM
Jake99
Aug 8, 2015 07:56 AM
elpyro89
Jul 28, 2015 05:51 PM
