Trying to run 17-18psi and driving daily???
Old Feb 18, 2010 | 12:14 AM
  #21
La Tu Papi's Avatar
Banned
Is he going to replace the head gasket if you pop one??? You would def be pushing it at that psi with out studs... If you had them, then it would be very doable..
This is not completely true, quite a few ppl have run stock TTY headbolts and MLS gaskets without pushing the gaskets out or lifting the heads. Being conservative and educated has alot to do with heads lifting
Old Feb 18, 2010 | 12:31 AM
  #22
EVILGMC's Avatar
18 psi is a **** pot load of energy on any engine..regardless of studs or bolts and turbo or roots.
what injectors are you running? how many fuel pumps? series or parallel?
10:1 compression?
Old Feb 18, 2010 | 08:59 AM
  #23
scooter k's Avatar
10:1 compression?
10.5:1
60 lb injectors
one fuel pump controlled by the FPCM
Old Feb 18, 2010 | 10:25 AM
  #24
Mangled03gmc's Avatar
Baltimore Whore
I am not going to get into a pee pee match, but how can you be conservative with 18psi.. 18 lbs is 18 lbs.. Why try to do it, knowing that there is a pretty good chance your going to pop one, along with all the people telling you that it is very possible it will occur..
Old Feb 18, 2010 | 10:33 AM
  #25
La Tu Papi's Avatar
Banned
Well this is where your little uneducated on the difference between pressure and volume. Just cause you have restriction to reach 18psi doesnt mean you see the volume of a less restrictive setup at 18psi. The larger the unit the more volume youll see at the stated PSI level. Charge temp has alot to do with cylinder pressure as well. A maggie is nothing more then a heat pump so the IATs of that setup will be much higher then that of a large turbo.
It also comes down to DCR of a motor as well as SCR. The lower those values are the more volume you can stuff into the cylinder. A 10.5scr motor wont handle that amount of volume as well as a 8.0scr motor with given same volume.
Alot of ppl dont have actual real world experience they just repeat what they read on the net, or they do have setups that were tuned wrong, setup wrong or are just idiots when putting a build together.
Old Feb 18, 2010 | 10:44 AM
  #26
LsxCody's Avatar
smart guy lol, just be safe with it
Old Feb 18, 2010 | 12:22 PM
  #27
denali_on_26's's Avatar
From: Where our street cars are faster than your racecars..Mississippi
in my SVT lightning
i ran 19lbs with the stock ported eaton on pump gas 454rwhp
i ran 16.5lbs with the whipple 2.3 and a 75shot 647rwhp/721rwhp
i ran 19-21psi with the 76mm turbo 719rwhp
all with OEM head studs and never had one single issue
i had 8.9.1 CR
Old Feb 18, 2010 | 01:03 PM
  #28
charcold-bowtie's Avatar
Why? I dont see you having any traction
Old Feb 18, 2010 | 02:13 PM
  #29
scooter k's Avatar
Four wheel drive.......
Old Feb 18, 2010 | 05:56 PM
  #30
scooter k's Avatar
Isn't detonation what lifts the heads?? If I tune it and don't have any KR won't it work out ok?
