Trying to run 17-18psi and driving daily???
Old Feb 16, 2010 | 04:21 PM
EVILGMC's Avatar
the heads will most likely lift or push water at about 15psi
Old Feb 16, 2010 | 04:56 PM
WJ MARK's Avatar
I would stay where you are at with boost, and just add some squeeze to the mix!!
Old Feb 17, 2010 | 07:07 AM
scooter k's Avatar
Talked with Erik at HK engines and he said I will be fine at 18psi. No problems.
Old Feb 17, 2010 | 08:46 AM
LsxCody's Avatar
well good luck with more boost
Old Feb 17, 2010 | 04:59 PM
tarinitup's Avatar
9 Second Truck Club
I would say your fuel system is going to determine how far you go on boost. I'd like to know how far myself since 12lbs feels slow already.
Old Feb 17, 2010 | 07:46 PM
scooter k's Avatar
The meth is supposed to help take the load off fuel pump.
Old Feb 17, 2010 | 10:57 PM
TX Tahoe Z71's Avatar
Go big or go home
Old Feb 17, 2010 | 11:02 PM
WJ MARK's Avatar
and cool that hot air the TVS puts out!
Old Feb 17, 2010 | 11:03 PM
Mangled03gmc's Avatar
Baltimore Whore
Is he going to replace the head gasket if you pop one??? You would def be pushing it at that psi with out studs... If you had them, then it would be very doable..
Old Feb 17, 2010 | 11:58 PM
ONLYA4.8L's Avatar
I recommend arp.. They kept my heads on when I was running 175shot in my lil 4.8l
