Trick Turbo review-1 year later
Old Jul 2, 2008 | 07:53 PM
Slowhawk's Avatar
LS1Tech Sponsor
Default Trick Turbo review-1 year later
Figured I'd give a review after a year and 20k miles.
I got the basic kit jet hot coated with the 62mm turbo for my cam only 5.3.The basic kit took 3 hr's to put on,then I added a cheap 3" intercooler. At 7lbs of boost I gained 170hp/190tq with full spool at 1800rpm.Stock tranny blew within 500 miles.
As for the quality?A year later I never had a problem with the kit or engine.(except oil drain line that I lazilly did)The coating still looks new after the New England winter and the turbo has the normal turbo rust.I didn't touch 1 bolt on the motor/kit since the install.Today was the first time I changed the plugs since install and they all looked extremely good,good enough that I wanted to put them back in for another year.This truck also gets an oil change every 6-7k miles and doesn't use a drop.
So I just wanted to say thanks to Trick Performance for building such a good durable turbo kit.This thing definitely exceeded my expectations of quality and power.
Don
Old Jul 2, 2008 | 07:58 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
that's a great review, outstanding!
Old Jul 2, 2008 | 08:11 PM
SpoolinChevy's Avatar
Sounds like she's still running strong. +1 for Rick.
Old Jul 2, 2008 | 09:34 PM
IMD's Avatar
IMD
Banned
full boost at 1800 rpm? :skeptical:
Old Jul 2, 2008 | 09:56 PM
quicksilverado's Avatar
Do you have an aftermarket tq converter or factory?
Old Jul 2, 2008 | 11:22 PM
kbracing96's Avatar
Did you change how you did the oil drain? I know how you had it, is it still like that on the bottom of the front part of the pan?
Old Jul 2, 2008 | 11:24 PM
nonnieselman's Avatar
I see 4psi at 1600rpms on my STS, thats with the converter locked in 4th tho.
Old Jul 3, 2008 | 06:53 AM
TrickTurbo's Avatar
Truck Sponsor
Don
Thanks Don, I am glad you are enjoying your kit. It is also good to see with good tuning, and maintaince what you can get out of one our kits.
Keep me posted.
Old Jul 3, 2008 | 08:28 AM
Slowhawk's Avatar
LS1Tech Sponsor
I had the stock converter in the first tranny.After that blew I bought a fully built 4L80 with a small 1800 converter.
Last edited by BlownChevy; Jul 3, 2008 at 02:02 PM. Reason: quit posting your dam sig
Old Jul 3, 2008 | 08:29 AM
Slowhawk's Avatar
LS1Tech Sponsor
The drain at the bottom worked great until the outside temp hit under 10 degree's.Then it wouldn't drain right.So I moved it to the front of the oil pan and never had the problem again.
