Trick turbo installation and review
#441
Not sure how that can is plumbed. Just ensure that no air that has passed through the MAF is ever vented and that no air that has not passed through the MAF is drawn into the intake.
Looks like some funky stuff going on with your timing just cruising even when there is no knock.
#444
There is no vacuum source per se. His line that introduces very little vacuum, as I showed in my previous post, is connected to his catch can an inch from a huge breather cap. The can has zero vacuum in it. Zero. The only way something is getting to the can is from pressure in the valve covers. :/ His setup right now is no different from drilling a hole in the intake pipe and sticking two breather caps on the valve covers.
The amount of oil in that can is ridiculous. Only thing I can think of off the top my head right now is a bad seal in the turbo, pushing boost through the chra, in the oil drain, thus pressurizing the crankcase.
Post #32.
#445
I appreciate all the help guys. This truck is stressing me out for sure. So for now i have ran both valve covers to the can so they are just vented. I want to see if the can fills up with oil this way. Fresh air and vac source are plugged.
If a turbo seal is bad what seal would it be? How would I check it to find out? Thanks again.
#447
#448
Truck Sponsor
That's easy to tell.
if a seal was bad you will a huge amount of oil in your inter cooler piping.
Or you will be smoking like a freight train. Out the exhaust.
Turbos don't have 100% perfect seals. They have rings. You can have oil out the exhaust and the turbo be find.
If the oil drain is not going down hill or any type of restriction.
Can cause that issue. But that's not what you are seeing.
Even a poorly venting crankcase can cause what some call bad rings.
The oil has to be allowed to drain. Again this is not what your showing.
The catch can is catching a bunch of oil since its from the valve covers it's doing its job.
But why is there so much oil is the question.
And no it's not a 150.00 turbo.
