Trick Performance Products Turbo Kit
Old Nov 17, 2011 | 09:04 AM
Junkyard Dog's Avatar
Default Trick Performance Products Turbo Kit
Is anybody running this?
Trick Performance Products Turbo Kits
If so, what was the result?
Considering for a 4.8 in a 2005 Yukon. That and a hotter cam and a higher stall speed . . . maybe lower the gears from 3.23 down to 3.73?
Thoughts?
Old Nov 17, 2011 | 10:59 AM
carbongmc's Avatar
Im running it on my 5.3, but I made my own intercooler set up and installed a snow stage 1 meth kit on top of that. Im very happy with it overall.
Old Nov 17, 2011 | 11:10 AM
Can you tell me some about what it is like to drive it before (stock) and after? Any performance numbers? Are you at 7 psi?
Old Nov 17, 2011 | 11:33 AM
02'Z71ONDUBZ''s Avatar
Its a night and day difference, you will nearly double your hp depending on your boost level. Im guessing you've never been in a turbo truck... Check out some vids on youtube to give you a visual
Old Nov 17, 2011 | 11:49 AM
Nope - never had one, but I have a Volvo with a turbo, and it is so much fun that I started thinking, I need to get one of these on my truck!
Old Nov 17, 2011 | 11:58 AM
carbongmc's Avatar
Out of boost driving will be the same in my opinion, at least it is on my truck. Im running 10psi, and before the cam and headwork, it made 543rwhp. Its a beast! Just make sure your tuning is dead on.
Old Nov 17, 2011 | 01:28 PM
14psisupra's Avatar
mine should be done early next week, ill post the results
Old Nov 17, 2011 | 02:01 PM
Wow! That is pretty amazing for at the wheels with only 10psi. What is it making now with the cam (which one?) and headwork?
Yes, please do! This is all very interesting.
Old Nov 17, 2011 | 02:20 PM
Mangled03gmc's Avatar
Baltimore Whore
You need to start looking for a trans if you plan to add HP to a suv.. Power plus 5k Plus = BANG
Old Nov 17, 2011 | 02:31 PM
jrmchevyman's Avatar
^ yep, It wouldn't be as bad if you had a Reg cab truck or a Ls1 camaro for that matter, but with that heavy beast of an suv you will start breaking stuff lol.
I'd really recommend running a safe very conservative tune maybe 5psi until you can save up for a new built trans, unless you don't care if you tear **** up.
