Trick oil kit.
Needs a return line pump similar to "STS" "rear-mount" setups in order to puke it back in through the the oil fill cap. If the Turbo was "high enough", it would work by gravity, but then, you'd have to cut an opening through the hood for the turbo to fit. It could work, if you wanted everyone to see that you had a turbo, and not heat up the engine bay too much.
I drilled and tapped mine on the truck. I later had to pull it due to breaking off one of the oil cooler adapter plate bolts off in the pan. When I pulled the pan there were shavings at the bottom. I took my time selling and used a lot of grease.
I meant to say to low
Yeah, but what's the thickness of timing chain cover? Last time I had mine off I don't recall it being that thick to be able to tap it. Would likely have to weld it in. Personally, I'm just going to pull my pan off. Just get the underside crossmember out and then get the pan off. Piece of mind to do it that way. That's for 2wd.
