trick manifold 80mm magnum help!
Old Nov 26, 2013 | 09:11 PM
99LS1Bird's Avatar
Default trick manifold 80mm magnum help!
Im helping a buddy with his build and the bolt hole of the turbo don't line up with the holes of the trick manifold. Now from everything ive read they are both t4 flanges and I cant find anything that says other wise. Help!!!
Old Nov 26, 2013 | 09:14 PM
TrickTurbo's Avatar
Truck Sponsor
80mm is T5.
You will need to pull the exhaust housing off.
Drill the holes in close. If you have a mill.
If not.
Take t4 gasket. Map out the pattern and use a grinder. To oval the holes out.
Old Nov 26, 2013 | 09:17 PM
99LS1Bird's Avatar
thank you!
OHsixLS3
Nov 22, 2015 07:45 PM
nabozny21
Oct 17, 2015 07:47 PM
JordanH
Oct 3, 2015 03:59 PM
LSX-81-SIERRA
Oct 2, 2015 07:05 AM
