transmission mission
Old Jul 28, 2011 | 08:14 PM
russellisabel's Avatar
Default transmission mission
i got 565rwhp and am using a yank 3000 stall converter, billet servos a hardened plate, and a transgo hd kit, however i think i tosted it. as i pull away from a stop in reverse or drive i get a banging like something is binding but as soon as i get rolling it goes away. crusies normal on the hwy shifts fine and everything only when i come to a stop. any ideas what broke? i pulled the front shaft out and its still doing it so its defently the tranny. also if it is should i go with a top of the line level 7 4l60e or just do the 4l80e? the 4l60e built would be eaiser and quicker. i do have a 4l80e conversion but it would need to be freshend up or at least a check up and another $1000 for a new converter plus the install (also cutting and moving the crossmember)and reflash of the cpu. what to do?????
Old Jul 28, 2011 | 08:45 PM
black04's Avatar
being boosted in an avalanche i'd go for the 80e
Old Jul 28, 2011 | 09:07 PM
what do you think broke? ive had 1st & 2nd clutch plate go and ihad it redone then 3rd and 4th went on (a stock set up) and ive never had a symptom like this its weird?? any ideas?
Old Jul 30, 2011 | 04:57 PM
Bromaguire's Avatar
From the way you describe the noise its sounds very similar to when I had my rear diff break.
bearden86
26
Nov 15, 2015 03:58 PM
dsbodley
Nov 14, 2015 09:46 PM
nabozny21
Oct 17, 2015 07:47 PM
jscherbs
Sep 30, 2015 07:54 AM
