Torque specs for Radix J-tube?
Old Jan 23, 2007 | 07:12 PM
Stoichiometric's Avatar
Default Torque specs for Radix J-tube?
Should I get it "pretty tight", or does anyone have a torque spec for the J-tube? Thanks in advance
Old Jan 23, 2007 | 07:52 PM
KySilverado's Avatar
Pretty tight, IMO. There would be now way in hell you'd get a torque wrench in there if you are doing it with the engine in the truck I could barely get my hands and tools in there.
Old Jan 23, 2007 | 11:24 PM
The flange sealant that I have is pretty forgiving. The blower is sitting on the floor so I'll try 18 ft. lbs. I am sure anything close to that should be fine. Thanks for the help.
Old Apr 8, 2007 | 11:13 AM
BLASTER's Avatar
I plan to pull the blower off to install mine.
Does anyone know the correct spec or did 18ft lb work?
tanx
Old Apr 8, 2007 | 11:46 AM
moregrip's Avatar
what a rush!
I'm pretty sure it's 18ftlbs
Old Apr 8, 2007 | 12:33 PM
I went with 20 ft/lbs. I have no leaks, I am sure 18 would be fine also!
Old Apr 8, 2007 | 01:01 PM
moregrip's Avatar
what a rush!
uh oh, now you you've done it
madmann26
Apr 29, 2020 09:17 AM
Jake75
Oct 2, 2015 02:28 PM
Wolftrk99
Oct 2, 2015 08:17 AM
Cammed4ever
Sep 30, 2015 03:38 PM
jscherbs
Sep 30, 2015 07:54 AM
