Timing+Boost+Octane
#32
I run 11psi @ 19deg timing on 91/93 octane no meth sitting around 11.7 afr wot. No knock
im wanting to run around 25deg once i get meth on. then uping the boost to 15psi to see what happens.
I like this thread... good info
#33
#36
#37
#38
On my best run with 93 octane, meth, and 14psi I started at 22 degrees, and went through the traps at 20 degrees. I have it backed off now.
I was talking to my GF's father the other day about his tractor. He is running alcohol in the upper 90 for boost (he has hit 110+), and is running 30 degrees of timing!
