Thoughts of Upping the boost?
Old Sep 23, 2009 | 08:30 PM
broke1's Avatar
Banned
If you dont have one already,get a methanol injection kit,progreesive.Every FI car that gets driven on pump gas should have a kit.They not only make more power,they keep octane up and keeps the inside of the engine clean.
Theres a guy in FL that makes a real nice kit for the GM trucks that looks factory.
Old Sep 23, 2009 | 09:30 PM
nonnieselman's Avatar
ive ran 14psi on mine a few times
stop asking questions and just turn it up.. i mean if im spraying on top of 10 and 12psi i dont think you should be scared of just 10psi...
if it were me, id get a differential before i did anything else. just to be on the safe side and possible save that new trans..
i think my truck gets used more than yours anyway, whens the last time you towed 8000#??
its a tow truck anyway.. who in their right mind wants to make a full size truck fast?
like the idea of the Water/Meth kit also.. i got one just to clean the inside of the engine for when i do the head swap..
Old Sep 23, 2009 | 09:41 PM
broke1's Avatar
Banned
Not water meth,just meth.Has been proven time and agiain to make more hp with cooler IAT's using 100% methanol.
Old Sep 23, 2009 | 09:52 PM
nlawson6.0's Avatar
3.5 psi hahaha did the wg open as soon as it hit boost?
i started with 10psi and wanted more right away. i have a felling, I will allways want to more.
-Nate
Old Sep 23, 2009 | 09:58 PM
what pumps out there will handle 100% Methanol?
Old Sep 23, 2009 | 10:02 PM
broke1's Avatar
Banned
Many of them although only 1 is rated for 100% by Shurflo.
I have ran 100% methanol on my cars for well over 10 years and never had a pump failure,never.
The kits I like to use,also the same guy who makes the GM truck kit that looks stock,the maker modifies the pumps he gets from Shurflo.
Old Sep 23, 2009 | 10:09 PM
nlawson6.0's Avatar
Devils Own should.
Kyle's been running straight meth through his. i believe he killed a old pump but may of been a few years of use. Their new pumps are better and should handle it.
Old Sep 23, 2009 | 10:53 PM
AH!! didnt know that.. its time for a methanol fill up anyway..
thanks guys.
Old Sep 23, 2009 | 11:07 PM
53RUSSELL's Avatar
I had my truck on 10lb for 30k and truck now has 163k
Old Sep 24, 2009 | 12:43 AM
thunder550's Avatar
High on diesel fumes
Alkycontrol's pumps are rated for 100% methanol now too. Been running straight meth on mine for over two years with no issues.
