Thoughts on turbo cam?
Old Sep 11, 2010 | 09:45 PM
HIPSI's Avatar
Default Thoughts on turbo cam?
I just wanted everyones opinion on theses two cams to see witch one they thinks best.
First is a Pat G cam - Comp XE/XE high lift lobes 214/218 .559”/.563” 116LSA +1 advance
next is a Stock48 212/212 .561" 114LSA
I'll be running the kbracing kit with a pt 76mm .81 ar, 3.42 gears and eventually 3k stall when the 4l60 goes.
Old Sep 12, 2010 | 02:27 PM
foose04's Avatar
If your willing to buy new, check out "cam motion", heard good things about there cams for FI.
Old Sep 12, 2010 | 03:44 PM
HIPSI's Avatar
looks like all there turbo cams are reverse split...
Old Sep 12, 2010 | 07:50 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Try predator z on tech, flowtech inductions, and Texas Speed are all people I would consult too for cam choice advice.
Im definitely a fan of a small cam for the 5.3, either of those would be pretty good.
Old Sep 12, 2010 | 11:13 PM
i believe stock48's cam got him in the 10's with a 76mm turbo. 2 of my buddy's are running that exact cam
Old Sep 19, 2010 | 09:05 PM
HIPSI's Avatar
Any more opinions on these two cams? What about the ls6 cam? Looks to be a popular turbo cam
Old Sep 19, 2010 | 10:22 PM
Three6GMC's Avatar
what are the specs on the new 5.3 cams are they any good for FI?
Old Sep 20, 2010 | 11:44 AM
TURBHOE's Avatar
Mine is a pat g / geoff speced cam. 215 218 intake lobe is a LSL lobe the exhaust is a lsg lobe. Iirc 114+1.
Old Sep 20, 2010 | 12:02 PM
charcold-bowtie's Avatar
ls6 is a good cam for the price. ie your dad cammed his vette and gave you one. These people that buy a new one from GM are a bit crazy IMO.
Old Sep 20, 2010 | 02:38 PM
02'Z71ONDUBZ''s Avatar
I thought stock48 ran the Isky 215???
