Thought I threw a belt...
Old Aug 25, 2011 | 02:46 PM
BigKID's Avatar
Default Thought I threw a belt...
I got on the truck a little the other day on a straight stretch of road to my neighborhood, part throttle but in boost (enough that the Nittos were fighting for traction) when power dropped off and I let out. Go to turn in the neighborhood... no power steering, voltmeter is at 12V and boost gauge doesn't go over 0 with a quick jab of the throttle. First impression is I tossed the belt. I have only thrown a belt on my KB setup once in the 4 years I have had it and that was due to a misaligned blower pulley. Well I get out, pop the hood and this is what I see...
Belt is a Dayco PolyRib and has been on the truck a little under 3 years. Other than being snapped in half, belt looks pretty good.
I checked the blower and all accs for binding which there was none. Are you supercharged guys (maggy, whipple, procharger, vortec, etc) snapping belts after only a few years use? I have had all my 8-rib swap parts for a few months, I guess it is time to install them. I will be running the Gates green HD belt with the new setup.
Old Aug 25, 2011 | 03:25 PM
slowec's Avatar
Good time to do the upgrade. Bummer on the belt pop though. Might check lightningrodder.com as most all of them use belt for boost.
Old Aug 25, 2011 | 03:35 PM
Mangled03gmc's Avatar
Baltimore Whore
I was puking belts like crazy.. Switched to a gates, have been running it for over a year now( cross fingers)
Old Aug 25, 2011 | 03:49 PM
lownslo's Avatar
ha I can throw a belt and still have boost , sucks to hear ya broke a belt but give ya a good excuse to do the 8 rib now!
Old Aug 25, 2011 | 04:12 PM
BigKID's Avatar
6 or 8 rib? When you switch to Gates, regular or HD?
Old Aug 25, 2011 | 04:59 PM
03sierraslt's Avatar
I am running a gates HD with good luck so far. On my KB I used to run gatorbacks and never broke one. Changed them every year though
Old Aug 25, 2011 | 05:09 PM
Baltimore Whore
Gates HD, 6 rib.. That Procharger ate gator backs like candy
Old Aug 25, 2011 | 07:51 PM
TIM Z's Avatar
11 sec. Truck Mod
Dayco has served me well.
But i think its prob good practice to change belts every year. Its cheap insurance.
BTW your setup looks great!
Old Aug 26, 2011 | 01:05 PM
BigKID's Avatar
Then stay tuned Tim as I plan to clean up some things with the acc drive and bracketry when I do the 8-rib swap.
I guess the belt served it's time given the amount of stress it had to endure. I did have it on there pretty tight to try and counter the belt slip I got when I put on the 3.25" pulley.
Old Aug 26, 2011 | 01:17 PM
rjwz28's Avatar
Man Motor club
Subscribed for belt intel
