thinking about procharging
Old Mar 5, 2010 | 10:32 PM
jdfarmboy6420's Avatar
Default thinking about procharging
all right im run a stock lq4 and im looking at put a procharger on it, what would you guys recrommend run and how much boost. Im also looking at putting stronger pistons and rods in but keeping stock compression. Any information or recomandations would be great.
Old Mar 5, 2010 | 10:33 PM
00ChevyScott's Avatar
Wearin' da big hat
What year LQ4 is it?
And you're going to want to add a cam, converter, tranny, and possibly gears to that list.
Old Mar 5, 2010 | 10:38 PM
Its a 01 and i was going to keep the stock 4l80e but change the shift points and put in 4.10s as for a cam i have heard that a stock cam is a good all around cam, so i was going to keep it. i might plave a little higher stall converter in the truck to get a better launch off the line.
Old Mar 5, 2010 | 10:41 PM
Wearin' da big hat
Prochargers need a higher stall converter to really get you into the power band. Also, a cam helps a ton with a procharger from what I've seen.
Old Mar 5, 2010 | 10:43 PM
any recromendations on a charger and cam then?
Old Mar 5, 2010 | 10:45 PM
Wearin' da big hat
There's nothing wrong with the prochargers, with the right mods they absolutely fly.
But if you're wanting more of a "just throw it on there and run it" type setup, then you might be interested in the Magnacharger TVS 1900 setup.
Old Mar 5, 2010 | 10:48 PM
ok thanks, i don't really care it its a easy set up because i can do most of the programing and stuff myself. Wat kind of boost are most people running?
Old Mar 6, 2010 | 12:09 AM
Blowndenalixl's Avatar
I only run around 5lbs max. Without my 3200 torque converter, I was just sligthly under 7 seconds 0-60. With the 3200 torque converter, I am just under 5 seconds 0-60.
Lesson is get a torque converter!
Old Mar 6, 2010 | 04:26 AM
Badboy464's Avatar
I have an sts kit for sale PM me.
Old Mar 6, 2010 | 04:10 PM
idahoblkss's Avatar
a p1 procharger will give you plenty of power and with a 3.7 pulley you'll have about 9lbs of boost, personally i would recommend getting the d1 procharger if you want to push it.
with a p1 and a 3k + stall youll have a real low 13's high 12's second truck with out a doubt in my mind.
D1SCSS
Jan 25, 2016 10:14 PM
echoman
Aug 22, 2015 01:53 PM
blownss27
Aug 14, 2015 03:31 PM
fcompean
Jul 15, 2015 09:55 PM
lo4x4
Jul 5, 2015 05:58 AM
