testing the fit
Old Apr 21, 2009 | 03:38 PM
Midnightrider's Avatar
Default testing the fit
well gotta make some modifications. The drivers side down pipe is gonna hit the vacuum assist pump. couple options are to relocate the vacuum assist pump. Option 2 is to get a housing that feeds from center which would actually center the turbos and they would look better under the hood. No biggie hiccups are expected. here are some pics
Old Apr 21, 2009 | 04:01 PM
lownslo's Avatar
nice now box it up and send it to me so i can do a test fit on mine......just wanna make sure its not too much boost for you!
plus you don't need that crap get it off your truck it looks bad on there!
Old Apr 21, 2009 | 05:15 PM
OnyxSilveradoSS's Avatar
nice glad to see its going on.
Old Apr 23, 2009 | 11:50 PM
gmc6.0's Avatar
very nice....where did u get that kit from...
Old Apr 24, 2009 | 01:23 AM
SpoolinChevy's Avatar
Lookin good. What size turbo's are those?
Old Apr 24, 2009 | 08:50 AM
t_thall's Avatar
i think on-center housings hurt flow a little
Old Apr 24, 2009 | 09:21 AM
Rick_Vor's Avatar
I ran into the same problem with the brake boost assist. I just bent the bracket 90 degrees and moved it out of the way. You will have to add a short piece of rubber hose to re-connect.
Where are you planning to mount the FMIC? In front of the radiator or down below it? If front is a bunch closer but the plumbing is harder. I had to do a lot of cutting/trimming including the headlight mounts.
Rick
Old Apr 24, 2009 | 11:13 AM
jow02327's Avatar
im not positive rick but i think his kit came with dual air to water intercoolers
Old Apr 24, 2009 | 11:50 AM
silver-mod-o's Avatar
Hunt&Fisherator
lookin good.... whats the total specs on that kit/motor??
Old Apr 24, 2009 | 01:53 PM
kbracing96's Avatar
It's Yellowseira's old kit he built himself, A nice piece
