tc78 1.52
Old Oct 7, 2013 | 03:13 AM
TURBHOE's Avatar
Default tc78 1.52
any body run the 1.32 or 1.52 A/R housings that turbonetics makes for the tc78? i'm thinking about going to the 1.52 being that i went to the 6.0 from the 5.3.
Old Oct 7, 2013 | 02:55 PM
TimDave217's Avatar
Wat? Is this a stock 6.0?? If not you No you won't need it.
Old Oct 7, 2013 | 04:30 PM
What size is the turbine. Thats the most important part
Old Oct 7, 2013 | 05:02 PM
TURBHOE's Avatar
It's a 68mm the f1-68. It falls on its face around 5200 or so.
Old Oct 7, 2013 | 05:03 PM
TURBHOE's Avatar
It's stock for the moment. Soon it will have cam and heads.
Old Oct 7, 2013 | 05:28 PM
Atomic's Avatar
I have a gauge for that
You need a bigger turbine. The bigger housing will just make it laggy.
Big turbine/small housing > small turbine/big housing
Old Oct 7, 2013 | 07:23 PM
TURBHOE's Avatar
I plan to go twins later. I just don't have the budget to do it right now. This is just to get me over for a while.
Old Oct 7, 2013 | 11:08 PM
TimDave217's Avatar
Hurricane benita will only spin so much air yep bigger turbine, that'll take days to do anything if you had the bigger housing. and if you do that you might as well go with there new 75mm turbo (i think thats the size) they got out. or just a BW.
Old Oct 8, 2013 | 01:47 AM
TURBHOE's Avatar
That math doesn't add up at all. I already have a tc78 on my truck. $300 for A housing is way less than most of the bigger turbos on the market.
Old Oct 8, 2013 | 08:26 AM
TimDave217's Avatar
Because you'd need a bigger wheel also. im not saying buy another turbo just an opinion my friend.
