tailpipe+Turbo
Old Feb 1, 2008 | 04:10 AM
sowaidi's Avatar
Default tailpipe+Turbo
after 3 months without a muffler or a tailpipe on my STS kit, i put one there today and i hate it because the truck wont make full boost and would only make it at higher RPMs. i didnt put a muffler, it is on a 3 inch tailpipe that goes on the right corner. what are you guys with turbos using as a tailpipe or what would you recommend?
Old Feb 1, 2008 | 03:43 PM
Mort's Avatar
I run a 3" tailpipe on mine and it seems to work fine. I have a TO4E housing with a .81A/R. Not sure why you are having this problem.
Old Feb 1, 2008 | 05:43 PM
sowaidi's Avatar
i have the same housing as yours but i will try to run a 4 inch pipe and wrap everything up. did i mention, i have lt headers. but it only came like that after the tailpipe
Old Feb 1, 2008 | 10:43 PM
kbracing96's Avatar
My STS 4.8 didn't come alive till I wrapped the tailpipe to the turbo and put a .68 housing on the T60. Those headers and unwrapped pipes are KILLING your egt's which you NEED greatly with a 4.8 and a rear mount. Your truck would be faster, spool better and be more fun to drive with stock manifolds, wrapped pipes to the turbo and a .68 housing. This I speak from experience. Also, I had the stock 2 3/4" tail pipe after the turbo from day one.
Old Feb 1, 2008 | 10:58 PM
explorer5.0's Avatar
TOTM: November '07
I have a 3" mandrel bent tailpipe, but it is only like 18" long. I am considering putting a big *** diesel tip on it since my exhaust sounds like a freaking Powerstroke's.
Old Feb 1, 2008 | 11:39 PM
BlownChevy's Avatar
blownerator
25 Year Member
Where did you put the muffler? I had mine after the turbo, and it helped ALLOT with the "whine".
Old Feb 2, 2008 | 12:34 AM
sowaidi's Avatar
i dont even have a muffler, its just a 3 inch pipe
Old Feb 2, 2008 | 12:59 AM
jus1975's Avatar
Has anyone put the turbo after the mufflers?
Old Feb 2, 2008 | 01:28 AM
FMOS Racing's Avatar
NOT a good idea. Mufflers are expansion chambers, they introduce a lot a turbulence and temperature drop. You want the airflow into the turbo to be as smooth and as hot as possible.
Can't imagine why a tailpipe caused that much issue. I don't see a whole lot of change on my front mount setup between open down pipe and cats/muffler. About 20 hp overall with a moderate change in midrange spool.
Old Feb 2, 2008 | 02:59 AM
jus1975's Avatar
Why do you need the exhaust to be hot? Is that just for the speed of the exhaust to flow faster. I just love the sound of my Magnaflows and I hate to get rid of them.
