t-76 .96ar S-trim!
Old Oct 13, 2007 | 10:03 AM
Derek @ EDO's Avatar
FormerVendor
Default t-76 .96ar S-trim!
how well will this work on a forged 370?
I thought it was a q-trim at first but its an s-trim?
someone please tell me the differences whether the S trim is better or worse.
Old Oct 13, 2007 | 04:40 PM
parish8's Avatar
single digit dreamer
i have been into turbos for awhile now and i can't answer that question. just too many options.
it could be a gts76. if it is then the hp potential is very high. 1150hp. a basic t76 wich i think is a q trim is rated for something like 900 or 950. i dont know if that is the S part or not. might be a s trim exhaust wheel and then i dont know what that means.
there are trims for the compresor and trims for the turbine. i think when you see something like "gts" the s is in refrence to the compresor.
in any case it will be great for a forged 6.0. max potential of at least 640rwhp but if it is the gts then well over 700rwhp cranked all the way up. i would say a prety good match up for lag vs max hp for a street/race truck.
does it have a 3" outlet on the compresor?
Old Oct 13, 2007 | 10:57 PM
FormerVendor
Hey Parish, Appreciate the response, it does have the 3" outlet.
Here is some info on the turbo
all I want is some 10's if this will get me there ill be happy
Old Oct 13, 2007 | 11:06 PM
TouchOfEvil04's Avatar
[QUOTE
all I want is some 10's if this will get me there ill be happy[/QUOTE]
Now you know your making stuff up lol. First it will be 10's then more meth then a small shot to spool faster then a bigger shot etc etc....all to go 9's lol.
Old Oct 13, 2007 | 11:23 PM
TurboGibbs's Avatar
I had a precision 76-gts on a 370 and at 10psi it made 539/578rw on 7 cyls. Spool time was very quick. It was a T4 flange, 4" inlet flange and a 3" turbine outlet on the downpipe.
Old Oct 13, 2007 | 11:26 PM
FormerVendor
sweet, this is sounding good!!
Old Oct 13, 2007 | 11:28 PM
TurboGibbs's Avatar
and mine was a .96 a/r
Thunder550 has my old set-up now.
Old Oct 13, 2007 | 11:36 PM
southern_chevy's Avatar
ya joe you are right today 10, next it will be a full drag truck.
Old Oct 14, 2007 | 08:26 AM
parish8's Avatar
just a guess but i think since it has the 3" outlet on the cover it is the "s cover" and rated for 1150hp. should be a bad *** turbo.
Old Oct 14, 2007 | 11:58 AM
FormerVendor
Parish, you have a PM
