T-72 Front mount, it finnaly runs!
Old Dec 19, 2007 | 11:25 PM
Default T-72 Front mount, it finally runs!
Well I finall was able to make some good runs on my truck.
99 gmc
6.0, cam, 4l80e, 3400 stall, t-72 front mount!
All I can say is wow!!!!
Only 7 psi and I can break them loose at 45. I really need traction now.
This is the first time I tune a turbo. I did a sd tune and I am still learning on it.
Would it be recommended to do a 2 bar sd tune or should i just stick to what I have?
Old Dec 19, 2007 | 11:30 PM
stock48's Avatar
9 Second Truck Club
That is really similar to my combination. Is that a trick front mount? What converter do you have. Im still running the MAFS , but wan't to go SD.
Old Dec 19, 2007 | 11:48 PM
It is a cm-motorsports. I have a precision vigilante 5 disc.
Old Dec 20, 2007 | 10:42 AM
thunder550's Avatar
High on diesel fumes
99 gmc
You would probably benefit from switching to a 2 bar SD tune....that's what most of the FI guys who do their own tuning are running.
Old Dec 20, 2007 | 10:45 AM
Bill Reid's Avatar
Pics or ban
Bill
Old Dec 20, 2007 | 01:05 PM
Does someone have a 2 bar i could take a look at to see what i am getting into?
Old Dec 20, 2007 | 03:30 PM
thunder550's Avatar
You want to look at the tune or the sensor?
Old Dec 20, 2007 | 03:50 PM
I would like to look at the tune.
I already have a 3bar sensor that i use th read the boost with my aero-scan gauge, i wonder if i could tie into it or would i have to use another one.
Old Dec 20, 2007 | 04:16 PM
kbracing96's Avatar
What software? If your gonna run less then 15lbs of boost, your better off with a 2 bar sensor, as you will have better resolution in the tune tables.
Old Dec 20, 2007 | 04:55 PM
Do you have a part # on the 2 bar?
For now I wont run more than 12 psi, if i can keep my hands off of the boost controller, lol!
My plans are to forge the engine in about 3 months, then it will be more than 15psi.
