Superdamper question. yes, i'm that dumb
Ok, I don't get it. I'm looking at superdampers online and i'm way confused. Mine looks similar to a stock harmonic balancer in that it has grooves for serpentine belts. How do the ones work that have no grooves? I don't get it. Are they for race only engines that don't use an alternator or mechanical water pump?
On old Small blocks the balancer was bolted to the crank and then the pulley was bolted to the balancer
Look at the pulley, there is an elastic ring between the 2 pieces of the pulley that does the harmonic dampening.
am i correct though? if you look at the ATI super dampers they have a few different kinds. the one i have is the serpentine damper. how about the ones with no grooves? clearly no belts can be attached to it right?
dantheman1540
Sep 18, 2015 03:03 AM
