What fuel? And do you run meth? |
93 Octane, and no meth.
Depending on compression 12psi is pushing it IMO on a daily with pump only. |
With a good tune (and a meth system is a solid fairly low cost option) there is no reason why you could not run 12psi with no troubles. What injectors? You MIGHT need a bigger pump or a second one to stay safe......
FIC Bosch 60Lb: https://fuelinjectorconnection.com/p...high-impedance
How much meth do you go through on a daily driver? Doesn't sound like something fun to deal with all the time. |
I ran 12psi on my 5.3 with no meth almost 10 years with zero issues daily driven in Texas weather
Meth systems can be set up to only come on at a certain boost psi I think. You shouldn't HAVE to run them all the time unless you are using it to crutch the octane rating and trying every trick for max power.
You can run quite a bit of boost on 93 only but there is a point where you have to kill so much timing your better off to run less boost and more timing. It’s all a trade off. |
(Post 5456988)
You can run quite a bit of boost on 93 only but there is a point where you have to kill so much timing your better off to run less boost and more timing. It’s all a trade off. Put a deposit on the L33 today, 96k miles. https://drive.google.com/open?id=0B8...44NzQ4YUVMNFdF |
Previous cam:
Tick Performance Blower Stage 1 V2 Camshaft 225/237 .62x"/.61x" LSA116+5 Other options: A & A Supercharged Camshaft This camshaft works very well with small centrifugal blowers on smaller engines. Drivability will be excellent with this camshaft. 220/230 .581/.591 116+3 BTR CENTRIFUGAL SUPERCHARGED TRUCK CAM 223/240 .610"/.588" 113+5 Grind # XA224/350-XA238/345-18+4 Street Performance Duration at .050: 224/238 118 Lobe Center Angle with a 114 Degree Intake Centerline Lift with 1.7 Rocker Arm Ratio: .595"/.587" Recommended Displacement: 5.3-6.2 Liter Engines |
