Supercharger Gaugees....
I like Boost, AFR and Fuel pressure gauges. Get creative, in my 03 I popped out the cubby holes in the center console, glassed it over and installed them there. Easy to go back to stock by replacing the cubby if you like later on. Out the way too, don't care to advertise what I've got personally.
I got the PLX dm100. I only have a wb hooked up now, but you can show up to 4 different gauges at the same time, or switch between them when you want.
I plan on wb, boost, fuel preasure, and trans temp.
Sorry for the horrible pic.
There are 4 different styles of gauges on it when it comes, but I think there are more you can download. You can customize the colors of anything on the gauges, like the needle, ticks, numbers, to whatever colors match your dash. To add a different sensor all you need is the sensor, and the PLX box, they all just plug together.
Yeah Ive been curious about "stacking" different gauge options with the plx.So pretty much you can get the boost,fuel pressure and wb all in one screen right?Thatd be sweet but if you download one of those custom screens you prolly couldnt see everything at once that you'd need.So could you hook up two screens to the same box "stack" theoretically?OR you could just get the wb set up and plug in your Iphone to the obII port and listen to tunes while your truck is being scanned while driving.I think its called "rev" if you got the Iphone.
That dash cover has always looked nice... I did the triple pillar pod with FP, EGT, and boost, starting from the bottom up all in autometer phantom guages, my LC-1's XD-16 gauge is in an autometer steering column pod. It actually looks pretty stock, except the pillar. I'm not a huge fan either but I wasn't gonna drop the coin on one of those dash covers, and I wasn't going to stick gauges displaying important info somewhere that they couldn't be read at a glance.
plus i never really been a big fan of the pillar setup
