suggestions on smoke
Old Aug 14, 2016 | 10:44 AM
tim wellington's Avatar
Default suggestions on smoke
engine fresh .after local machine shop screwed me over.problem At cold start up smokes after idling for 3 minutes smokes out of tail pipe .UNLESS AT start up I bring idle up to1800-2000 til engine temperature reach 180 then no smoke .afr open loop 13.2-13.6 ,number 6 feed to turbo no restrictor,number 10 drain .both valve covers vented with filters. suggestion any one?
Old Aug 14, 2016 | 10:55 AM
TXsilverado's Avatar
are you sure it's smoke and not moisture? what color is the smoke? white=coolant. blue=oil.
Old Aug 14, 2016 | 11:02 AM
Default smoke
blue .only smokes in the a.m. just odd if I bring idle up .til 180 deg no smoke .800 miles on fresh engine .rest of day fine. smokes only if it sits for more than 4-5 hrs
Old Aug 14, 2016 | 11:09 AM
rings expand with heat. what does your PCV system look like?
Old Aug 14, 2016 | 12:59 PM
TrickTurbo's Avatar
Truck Sponsor
Almost sounds like valve seals.
After sitting awhile oil getting past valves.
-6 is a large oil feed line. But shouldn't be the problem.
Old Aug 14, 2016 | 01:00 PM
Default pvc
just to vent from each valve cover .driver side gutted pcv valve to filter
Old Aug 14, 2016 | 06:30 PM
1FastBrick's Avatar
Custm2500's Rude Friend
As mentioned, likely valve seals.
Synthetic or conventional motor oil?
Old Aug 14, 2016 | 08:23 PM
Default conventional oil
my experience with valve seals smoke idle all the time.once truck warms no more smoke 10w30 valvoline
Old Aug 16, 2016 | 09:24 AM
Default oil feed
called precision turbo they said 76/75. i should be running -4 not -6 .anybody with 76/75 pt .running -4??
Old Aug 16, 2016 | 03:17 PM
TrickTurbo's Avatar
Truck Sponsor
I send out -4 on most kits.
