sts worth it?
Originally Posted by chevytat2
how about the vortech supercharger?
what kind of power were you making
so if guys are making close to or over 400 with a supercharger and like 350 with the sts why go with the sts?
You're not looking at the #s correctly...
There are people using every forced induction system under the sun to make great power but you have to look at the total picture. The mods they use and the amount of boost they are running AND their specific engine. I made around 550rwhp with my STS at 14-15psi. I was using low compression and stock 6.0L heads. Now I am making 435rwhp on a high compression motor with aftermarket heads but only 5.8psi through a Radix. See how things can be misleading if you dont look at the whole picture. In this instance one might conclude the Radix is better since boost is lower but obviously this isnt always the case.
I also like the tat, looks sweet.
The STS is much easier to grow with when your power needs change. I say when, not if, as HP is addictive! If you have your parts installed by someone local make sure to find out who specializes in certain products in the area. Don't buy a system and pay someone to learn on your dime. Your wallet and engine will thank you later.
Those would be my deal makers/breakers. You can't go too wrong on most of the kits out there.
Cam, meth, 10 tunes, intercooler, smaller pulleys, bigger bypass valves, etc later and it makes good power.
well for now im just looking for a little more kick in the pants
ive dealt with the Horsepower addiction on 2 z28s in the past few years
id like some good power,reliability(its gotta be a daily driver)
and some WOW factor in there is cool too
and not spend another 25000 in credit card debt like i did on the z28's
