STS with wide band come in
Old Apr 27, 2006 | 03:57 PM
blue 01's Avatar
Default STS with wide band come in
I got a Innovate standalone XD-1 with LC-1 which is a wide band O2 with a gauge kit. On there tuning forum I asked.
( How close after the STS Turbo can I mount the LC-1 O2. Then how long of a exhaust pipe do I need after the mounting location. I am not going to be using a muffler. This is on a 2001 5.3 GM sierra truck with OEM cats.)
There admin guy answered.
(No closer than 1 foot. But it depends on the EGTs. best is as far back as possible but at least a foot from the tailpipe and before the cat.)
I said ( STS turbo are after cats)
His response
(With a cat before turbo it's really not possible to use a WB sensor there. The readings won't be reliable. I hope you also budgeted enough $$ for cat replacements. They are not designed to live in the high pressure/temp environment pre-turbo for long.
About the only thing you could do (requires fabrication skills) is to tap off the exhaust to a small diameter steel tube (1/4" or less is sufficient) pre-cat and feed into a closed-off bung where the WB is mounted. Feed the outlet of that bung back into the exhaust, past turbo. Put a restriction (~1 mm) into the feed line just before the bung. This will give enough flow for the WB, but reduces the pressure and temp enough for the WB to function.
Please some one help. I thought when I searched on here that ever one was putting them after the turbo. And that is also were the dyno tuner puts his WB for AFR reading during tuning. Speed Engineering put the bung on my kit that I bought used about a foot after turbo to do the tuning on it.
Any input????
Heres is the link if you want to read the whole thread.
link
Old Apr 27, 2006 | 04:22 PM
spinz71's Avatar
Mine is located behind the turbo about 4-5 inches with another 3-4 inches of pipe after. Seems to work fine.
Old Apr 27, 2006 | 05:08 PM
vanillagorilla's Avatar
Seemed to work fine on the dyno. I have no cats though.
Old Apr 27, 2006 | 05:35 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
I was told 12-24inches from the turbo. Due to the axle, etc., mine is about 12 inches past the turbo. I don't run cats though.
Old Apr 27, 2006 | 06:24 PM
Wilde Racing's Avatar
How do I change this text
Same here. Mine is about 12" behing the turbo.
Old Apr 27, 2006 | 06:34 PM
blue 01's Avatar
With cat? How much pipe after WB O2 location?
Old Apr 27, 2006 | 06:45 PM
No cats. With the cut-out closed, up over the axle and out the right side near the bumper. It is about 10" from the cut-out. A bit too close for me.
I just took a pic but Photo Bucket is down.
Old Apr 27, 2006 | 07:09 PM
TIM Z's Avatar
11 sec. Truck Mod
with cats, 8-10 inches behind the turbo, works great.
Old Apr 28, 2006 | 12:11 AM
Hi Blue--with cats and 24"s behind the turbo and works great...
Old Apr 28, 2006 | 12:36 AM
blue 01's Avatar
Hey Timz and Hotrod04 how long from WB O2 to exit of exhaust pipe?
Thanks for ever ones input. I feel a lot better now.
Hotrod04 don't forget to send me a picture of your oil cap.
