sts turbo guys in here ASAP
You can get a new spring from TiAL that will raise your boost all the time or get a boost control so that you can adjust the boost as you see fit. STS offers a boost control that is simple and works fine. They also offer an electronic control to switch from the hi/low setting from the cab, but the hi setting still needs to be set originally or changed using the mechanical control.
How do I change this text
you will need some type of boost controller to bring your boost up, or a new spring....
I would suggest running 6psi for a while before you crank it up......
***EDIT*** Mort beat me too it....
I've got the boost controller from sts. It works good and has the switch in the cab to go from low to high. Once you set it, your good. I have it mounted close to the turbo with the controll *** hanging about an inch below the frame rail so if i want to change it, all i have to do is reach under and turn it. Without layin on the ground or getting dirty.
lxcoupe
07-21-2015 02:12 AM
