STS turbo clocking question
Old Apr 29, 2007 | 12:27 AM
speedaddict's Avatar
Default STS turbo clocking question
We have to do some modifying to the STS kit to fit under my lowered 01 silverado. I was just wondering about the turbo setting in the right position to avoid oiling troubles and other problems. What's the proper "clocked" setting for the turbo? What should I watch out for? Thanks in advance
speedy
Old Apr 29, 2007 | 12:45 AM
kbracing96's Avatar
Oil feed should be at 12 o-clock and drain should be 6 o-clock. It's easy to adjust, just loosen the housing bolts and twist them
Old Apr 29, 2007 | 09:40 AM
BlownChevy's Avatar
blownerator
25 Year Member
ten bucks!
Old Apr 29, 2007 | 10:12 AM
thanks! do you guys happen to have a couple pictures of your turbos underneath? Just for reference. I don't have STS instructions with my kit.
Old Apr 29, 2007 | 11:55 AM
BlownChevy's Avatar
blownerator
25 Year Member
Old Apr 29, 2007 | 12:37 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
I have the instructions from my kit you are welcome to borrow since you are in Austin.
Old Apr 29, 2007 | 02:26 PM
SWEET...lets meet up sometime this week if possible. I can just make copies and return it to you. Cool?
How much of the turbo hangs below the frame? and is that a resonator or muffler attatched???
Old Apr 29, 2007 | 03:11 PM
BlownChevy's Avatar
blownerator
25 Year Member
none of it hangs below the frame, yes it is a muffler after the turbo.
Old Apr 29, 2007 | 03:20 PM
Brian, thanks for your responses. This helps out a lot!
