STS Oil Return??
Old Jun 24, 2007 | 04:14 AM
  #21
Spoolin's Avatar
GFYS and STFU
Duuuhhhh...I'm a dumb ***!! I didn't think about what intake you were running. I have a Victor Jr. so it's alot easier to do it with my set-up. I'll see if I can snap some pics manana for u though.
Old Jun 24, 2007 | 10:33 AM
  #22
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
I had to position mine where it is at due to have a front diff to dodge too so you may be able to put yours elsewhere. From what I read on tech just make sure you return the oil above the oil level in the pan.
Its a -6 AN bung
Old Jun 24, 2007 | 10:11 PM
  #23
nonnieselman's Avatar
Cool... thanks bro!!!
What is that about 2-3" From the top of the Pan??? I have no idea where the oil line is.. i am goin to guess its above the Oil Level Sending Unit...
Old Jun 26, 2007 | 05:15 PM
  #24
1slow01Z71's Avatar
See the shiny thing sticking out about half-way down the pan towards teh front? Thats the bung. You can probably position yours further back since you arent 4wd.
Old Jun 27, 2007 | 05:10 PM
  #25
vanillagorilla's Avatar
Unhappy
I hate to ask this question buuuut.....I don't know about you guys, but my oil pan is well...oily. So how the hell do you guys effectively weld an aluminum bung to an oily-*** oil pan? Aluminum is pretty pourus, so all the oil is well soaked into my pan, probably all the way through it. I don't think I could get my pan clean enough to weld if I tried. Did you guys use the dishwasher or something?
Old Jun 27, 2007 | 05:52 PM
  #26
1slow01Z71's Avatar
I used alot of non-chloro brake cleaner on mine and wiped it down real good. Then I put it in one of our curing ovens at work and that brought out a little more oily residue then I cleaned that up and took it to my welder. He cut the hole in the pan the size of the chamfered part of the -6 bung and welded it from the inside. The weld looks good to me.
Old Jun 27, 2007 | 06:51 PM
  #27
Spoolin's Avatar
GFYS and STFU
Great work man! looks clean!
Old Jun 28, 2007 | 12:59 PM
  #28
Alirght, I'll try doing that. Unfortunatley we only have plastic ovens here and they get a little too hot for my liking when it comes to oil. I'll just use my oven at home.
Does anyone have any pics of an oil return on the driver's side, like for twins?
Old Jun 28, 2007 | 01:23 PM
  #29
kbracing96's Avatar
Parish has pics some where of his oil pan with returns on both sides, for the twins.
Old Jun 28, 2007 | 02:05 PM
  #30
Cool! Found them, thanks. This should be interesting.
