STS Oil Pump, how to wire it??
Old Mar 28, 2009 | 10:21 AM
FrostKing's Avatar
Running the pump in high all the time makes it more noisy and probably last half as long.
Old Mar 28, 2009 | 10:24 AM
FrostKing's Avatar
Originally Posted by SRT10KLLR
I wondered about that as the way STS has it the oil pump is t-tapped into the fuel pump so when you push the key to the "on" position it primes the fuel pump and the oil pump since they both get there signal together, right?
I don't think the oil pump needs priming, just that running it in conjunction with the fuel pump means it won't run continuously with the key on and engine off. (convenience)
Old Mar 28, 2009 | 12:53 PM
Ender06's Avatar
Originally Posted by FrostKing
The buzzer connects to the pressure switch at the oil pump inlet, alerting you if oil pressure builds above a few PSI inside the turbo. The Hobbs switch should connect to a relay and a high wattage resistor
Is the hobbs switch and the pressure switch you refer to the same thing, or two seperate parts??
Old Mar 28, 2009 | 04:30 PM
FrostKing's Avatar
Two separate parts. The pressure switch is 1/8" MPT (shown in picture on last page) and the Hobbs switch I had used very tiny 1/16" or 1/8" tubing.
Old Mar 28, 2009 | 04:39 PM
FrostKing's Avatar
Actually, I was confused. The pressure switch shown is a 'Hobbs' switch. It is a brand from Honeywell and not really a type of switch. Nonetheless, there should be two switches. One at the oil return pump that activates the alarm buzzer and a second connected to the manifold pressure that kicks the oil pump into high speed during boost.
Old Mar 28, 2009 | 07:10 PM
Ender06's Avatar
Ah, that clears it up somewhat, does the second one just hook into vacuum??
Old Mar 28, 2009 | 07:55 PM
FrostKing's Avatar
Yes, manifold pressure after the throttle body.
Old Mar 28, 2009 | 09:05 PM
SRT10KLLR's Avatar
Former Vendor
The one by the oil pump will go off if oil back up behind the pump to alert you that something is wrong. If you don't stop running or fix the issue oil will back up and go past the seals and you will have a smoke show on your hands.
The one up front activates the high speed when you hit 1lb of boost.
I have the one up front hooked to the vaccum from the brake booster per STS instructions.
Old Mar 29, 2009 | 12:56 AM
Ender06's Avatar
The buzzer connects to the pressure switch at the oil pump inlet, alerting you if oil pressure builds above a few PSI inside the turbo. The Hobbs switch should connect to a relay and a high wattage resistor.
Cant seem to find a high wattage resistor(bought kit used), whats it look like??
Old Mar 29, 2009 | 09:40 AM
Mort's Avatar
The resistor on mine attaches to the relay that installs above the AC Condenser. It is in a loop of yellow wire and is quite large with heat fins and gets quite hot. It is near the end of the STS wire harness that is run behind the engine along the firewall. That also has the connector for the wiring that runs from the oil return pump and hoobs switch.
