STS oil pump?
Old Feb 5, 2008 | 09:28 PM
2ktransam's Avatar
Default STS oil pump?
I think my oil pump is going bad so I am looking for a replacement. Has anyone tried this one?
3GPM Gear Pump 12 or 24 Volt
The compact GP-301 series gear pumps are designed to transfer lube oil, diesel fuel and water. Utilizing straight cut bronze gears and stainless steel shafts, the GP-301 transfers liquids up to 3 GPM. Used mainly for oil change and diesel fuel transfer, pre-luber, oil scavenging and similar applications. This pump will generate high pressures, but should be limited to 30-40 psi or damage to the motor will occur.
Draw: 12V - 10A, 24V-5A
Weight: 3 lb 6 oz
3/8" NPT male brass fittings on both sides.
Last edited by thunder550; Feb 5, 2008 at 10:43 PM. Reason: non-sponsor link removed. item information substituted
Old Feb 5, 2008 | 09:37 PM
vanillagorilla's Avatar
Why do you think it's going bad?
Old Feb 5, 2008 | 09:42 PM
2ktransam's Avatar
It got extremely noisy today. It happened a couple of times today when I pulled up to a stop light. It was on the low setting and it got so loud I could here it over my stereo. I bought the kit used so the pump has about 45k miles on it.
Old Feb 6, 2008 | 11:52 AM
Mort's Avatar
Do you have a link for that pump?
It looks like it may be the one STS uses and puts their name on. How much is it?
Sorry I don't know the specs for the STS pump but that pump looks like it will work.
These pumps are noisy on high. I have mine on high all the time because of the cold temps. I am not sure that indicates a problem. Maybe your STS PCV Hoobs switch is seeing enough boost (1 psi I think will do it) to put the pump on high speed and you can hear it.
Old Feb 6, 2008 | 12:20 PM
thunder550's Avatar
High on diesel fumes
There was a link there, but it was to a non-sponsor site so I deleted it. You'll have to handle it through PM's if you want to send a direct link. You can also name the site in a post, but don't link directly to it or include pricing info in the post.
Old Feb 6, 2008 | 12:25 PM
kbracing96's Avatar
PM sent about pump
Old Feb 6, 2008 | 12:51 PM
TG02Z71's Avatar
Had this saved.
www.
marine-electronics-unlimited.
com/Reverso+GP%2D301+Oil+Gear+Pump.html
You complete the linky.
Hope this is posting a link the nice way.
Old Feb 6, 2008 | 01:07 PM
Mort's Avatar
Thanks all... I think I will order a spare just in case..
Old Feb 6, 2008 | 01:52 PM
thunder550's Avatar
Works for me
Old Feb 6, 2008 | 03:00 PM
2ktransam's Avatar
I don't blame ya. I just ordered one too incase mine is going out. Thanks guys.
