STS Methanol instructions.
Old Mar 7, 2009 | 03:58 PM
dirt track racer 81's Avatar
Default STS Methanol instructions.
any one have them? not all the wires are explained on the harness..
Old Mar 7, 2009 | 05:11 PM
On the wiring harness to the sts methanol injection kit, were does the (Injector Ground Wire) go to? also the green wire on the harness does that go back to the valve to the boost controller by the turbo?
Old Mar 7, 2009 | 05:39 PM
viciousknid's Avatar
Where's the Beef?
there's another truck in the county i'm not gonna be able to touch. but hey, at least he's getting the exhaust fixed.
Old Mar 7, 2009 | 05:52 PM
Naw this aint Dannys...yet...this is a guys truck from Kansas Im workin on up at Dewaynes.
Old Mar 7, 2009 | 05:58 PM
Where's the Beef?
ohhh.
Old Mar 7, 2009 | 08:45 PM
FrostKing's Avatar
It's been a couple of years since I put mine in. The green wire is easiest to install at the high/low boost switch in the cab. (the opposite end of the solenoid valve) My kit came with a 12A solid state relay to ramp the meth pump up and down. The injector ground wire from this relay goes to my piggyback for progressive control, but it should work spliced into a fuel injector ground (through a Hobbs pressure switch when boost is made)
nabozny21
Oct 17, 2015 07:47 PM
sTNT971
Sep 26, 2015 04:22 PM
Benloe
Sep 22, 2015 10:24 PM
jeff.ellis
Aug 18, 2015 10:34 PM
ZO6Ted
Aug 12, 2015 07:50 PM
