STS kit ON only 4psi
GFYS and STFU
That's your problem right there! That's a pretty big A/R for a 4.8 At least your not gonna run out of turbo at higher RPM's. But then again with your manual so you can pick when you wanna drop the clutch.
The fact that it's a 5 speed isn't helping first gear spool. It got a deep 1rst gear that doesn't load the turbo very hard, so it doesn't build boost too fast. Wrapping the exhause and putting a .68 A/R exhaust housing on it will make a lot of difference. That's what I had on mine and it boosted quite well.
