Stock Truck Map Sensor for Boost Tuning (SD Tune)
#21
In theory, the stock MAP sensor will not be able to detect any changes in pressure above ambient. Scaling an output that isn't changing won't be of any use.
What's wrong with the IAT that's in the MAF sensor?
#22
Sure, if he scaled it.
I maxed out a stock maf on 10psi with a 5.3...I didnt want to bother with scaling so I just went straight 2bar sd on that setup and its been great. If everything is tuned properly you will not notice a difference in table resolution between the 2 and 3 bar. Hell I ran NA for a while on a 3bar sensor. The lower resolution is not that big of a deal.
#24
Aem Air Inlet Intake Temperature Temp Sensor Kit AIT | eBay
#27
This is true but he is spraying 3 meth nozzles and using e85 or race gas for safety. Jarrett is also doing his own tuning so he can make adjustments on the fly. I guess the pixie dust is magic that won't work with a 2 bar sensor.
#30
Can any recommend one over the other from the point of better tuning and idle characteristic. I mean GM 3-bar vs GM Dmax 3.3 bar map sensors.
