stock "New I/C'd KB" results
"We finished the Kenne Bell install on a stock 01 Z06 last week. Unfortunately it got the dreaded column lock failure and had to go to the dealer on Monday. They finished it yesterday but I got hurt and couldn't get it until today.
I'm just posting this because I've had a lot of you asking for the final results.
496 RWHP and 483 RWT. Air fuel is just under 12:1 and it has as much timing as the motor will stand without getting into detonation. That's all we or any tuner can do.
Now remember, this is an 01 Z06. An 02- 04 would be about 20- 25 RWHP ahead of this.
It made almost 8# of boost down low and tapered off to 7# up top.
The stock KB tune was actually designed around an 02 and up Z06 and wouldn't work with the 01. The smaller cam probably made more cylinder pressure down low. It rattled pretty hard on tip in.
I called them just to let them know what I'd found on the tuning.
They're going to work on a separate program for the 01 Z"(Andy@AandACorvette)
__________________
Why did the boost fall off? It should not have done that unless the belt is slipping or the intake is restrictive, right? Great none the less! Keep up the good work. We have the 02 Z06 motor at 8psi and it runs like a beast.
Originally Posted by MNC5
Wow, I was expecting a lot more even if it is new. I've seen better IC maggie #'s Thanks for sharing
Bill
just as i suspected.....boost and spark limited on a stock motor. Is it capeable of more on a forged set up, yes.....will it make alot more power than a Magnuson on a stock motor....NO.
A&A is well known for high HP set ups, and I know for a fact he was hoping for more on a stock motor. Just proved my theroy, thanks Andy!
BTW, saw the new M122 on the 07 Shelby Mustang in the new issue of Hot Rod... nice. The M122, IMO, is really going to give the KB 2.6 a run for its money.
Bill
zblee
Aug 3, 2015 03:45 AM
lxcoupe
Jul 30, 2015 02:42 PM
