Stock LQ4, TVS1900, 2.9 Pulley too much?
I recently installed a TVS1900 system on my 2003 GMC 2500HD 6.0L. Great system, btw. Engine is pretty much stock, long tubes, high flow cats, and super 40s.
Before I get the custom tune done I'm wondering if I shouldn't swap in a smaller pulley to utilize as much boost as I can. The TVS came with a 3.4 pulley (said to be 6lbs) and I have a 2.9 pulley (8.5-9lbs) available to use.
Assuming the tune is done right, do you think this is too much boost for an otherwise stock engine?
Thanks in advance for your input
You should also think about a cam.
The stock cam is so small that cylinder pressure up around 10PSI at low RPM is really high. A larger cam will make a ton more power... but its also "safer" to a certain extent.
I'll probably end up with the same sooner or later if that's the case. Any feedback on how the supplied Magnuson belt fits with the 2.9 pulley? One guy said I'd need a smaller belt, another said it should be fine.
Trevor @ Texas Speed & Perf.
Jan 18, 2002 10:38 PM
