Stock cam stock valve springs, 12 psi?
Old Dec 29, 2012 | 07:41 PM
98tdi's Avatar
Default Stock cam stock valve springs, 12 psi?
I am in the process of fabbing the hot side up on my turbo kit for my silverado. 67mm single turbo on a 265k mile stock 4.8 with a 4l80. I am prob going to get a cam and upgrade the springs later but wondered if it would be ok for meow?
What are your thoughts??
Going to float a valve? Risky, dumb, crazy??!!
Old Dec 29, 2012 | 07:52 PM
03sierraslt's Avatar
High mileage stock springs + 12psi would not be my pick. Replace the springs or be warned you may float and or drop a valve.
Old Dec 29, 2012 | 07:56 PM
stock48's Avatar
9 Second Truck Club
That's no good I would at least go for some used ls6 springs or something.
Old Dec 29, 2012 | 07:59 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
No go ghostrider!
Old Dec 29, 2012 | 08:04 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
I've always wanted to see the aftermath of something like this.
Old Dec 29, 2012 | 08:18 PM
TrickTurbo's Avatar
Truck Sponsor
Swap springs now. Do cam later.
Why 12psi??
Old Dec 29, 2012 | 10:30 PM
UnVmy5.3's Avatar
Mine is at 226000 and I'm doing the same thing gonna boost it on twelve pounds and let the stock motor have it. Even tho it's been a good one its seen better days I've hit a 150 on it since it turned over 175k it's been a champ
Old Dec 31, 2012 | 10:29 AM
98tdi's Avatar
Why 12psi??
No real reason other than that's what my tial spring is!
What springs do you recommend? I am going to purchase a isky triple 12 in the future
Old Dec 31, 2012 | 11:07 AM
black4.8's Avatar
you'll have to do the spring swap before hitting 12#. the seat pressure is probably a lot lower than stock w/ that many miles on them. valve float will definantly be a problem. i like the patriot dual extremes. very good price for what you get. they have the highest seat pressure i've seen. lots of pressure trying to open those valves. ls6 springs would be good cheap upgrade over stock if on a budget.
Old Dec 31, 2012 | 12:04 PM
Well either change your springs or keep us filled in when you kill the motor.
