Starting a new project. 4.8 turbo for sled pulling
Old 06-05-2012, 07:23 AM
gotmud2178's Avatar
Default Starting a new project. 4.8 turbo for sled pulling
Looking for ideas.
I'm thinking 4.8
1 or maybe 2 turbos
All engine parts are up in the air. I do want to keep the stock bottom end.
The engine will have a carb on it.
The truck is 4wd Dana 60 front 14ff rear 4.56 gears lockers front and rear t400 trans probable bout a 4000 stall. I'm gathering parts for my build so looking for opinions. It's being built to go 300 ft at a time not street legal so that leaves everything up for change.
Old 06-05-2012, 08:12 AM
03LQ9's Avatar
Good luck with your build, sounds like a great idea. Just curious, what class are you going to run in ? Around here gas engines have to be N/A.
Old 06-05-2012, 09:17 AM
gotmud2178's Avatar
We have an 8050 unlimited class.
Old 06-05-2012, 09:34 AM
JoeyGC5's Avatar
You can usually hop into the 2.8 or 3.0" turbo inlet size classes with a gas motor, really depends on the sanctioning body.
what fuel are you interested in running? How high do you want to spin the motor?
Old 06-05-2012, 07:11 PM
gotmud2178's Avatar
We run 116 in the other truck we put together and it spins over 8000 na.
Old 06-06-2012, 02:15 PM
Gingervitis Addict
slow67's Avatar
Stock Bottom End:
https://www.performancetrucks.net/fo...-going-485734/
Old 06-06-2012, 03:28 PM
JoeyGC5's Avatar
If your gonna spin in the 6k+ range I'd think a S475 or a S480 with race cover would be $ cheap enough but flow enough air to get some consistent #'s. All imo of course. Of course if they're gonna measure your inlet size and keep you in a 2.8 or 3" class then start looking at a s472 or maybe twin 55 or 62/66's
Old 06-08-2012, 02:38 PM
gotmud2178's Avatar
I was really thinking twins in the 60 to 70 range and try and keep the engine under 7000 rpms. And yes the other motor is spinning 8200 with a stock bottom end and it works great.
Old 06-08-2012, 02:41 PM
gotmud2178's Avatar
Ill be running a mod gas class so they dont measure the turbo. They diesel guys around here wont let the big block, NOS, supercharged or turboed trucks run there class. I guess there afraid to lose to a gas truck.
Old 06-08-2012, 03:28 PM
JoeyGC5's Avatar
The diesel guys use to bitch all the time about my turbo ccsb 6.0 truck. They spend all the money on new turbos, cp3's, and still get walked by a stock gas truck. Of course I had to say F'ck no to any 20k load they were always trying to pull across 4 states
Quick Reply: Starting a new project. 4.8 turbo for sled pulling
