Stage 2 Turbo Kit?
Old Jan 24, 2021 | 05:21 PM
mrcllusb's Avatar
Default Stage 2 Turbo Kit?
I am wondering how come there are no more small Turbo kits like a Stage 2? I have a 2011 Chevy 5.3L as a daily driver and I want to add a turbo kit for when we tow our trailers, but I can't find anything like a Stage 2 Kit anymore.
Old Jan 24, 2021 | 07:18 PM
pknowles's Avatar
I tow with my stage 3 kit. I can begin to make boost down at 1800 rpm and it spools so quickly, I wouldn't want a smaller turbo. You don't need to, but I turn the boost down to 5psi when towing. I'm sure the cost difference between a stage 2 and stage 3 kit would be so small that they probably dropped the stage 2.
Old Jan 24, 2021 | 07:20 PM
mrcllusb's Avatar
Thank you, I appreciate the info!! So Stage 3 but turn down the boost when towing! I have the Flex Fuel, so I'm looking for a simple bolt on turbo setup and tune and be done!
Old Jan 24, 2021 | 07:54 PM
pknowles's Avatar
I love my stage 3 kit and it tows well on 5 psi. There is nothing magic about 5psi and you can easily tow with more. Three months ago I turned it up to 8 psi and it pulled the trailer very well, although I had just built my 4L80E myself and was not ready to push it too much. I took out the stock cubby hole in the dash to the right of the radio and put a 60mm eBoost 2 electronic controller there. Just tap a button and go from 5psi up to whatever you want. The other option is to control boost with your right foot. The turbo kit was the best mod I ever made to the truck, towing is transformed. I have not towed in high heat yet (COVID killed racing this summer), but I can't imagine a problem with the boost set low. I wouldn't want to scream up a long hill at 15+ psi and melt everything under the hood.
Old Jan 24, 2021 | 08:02 PM
mrcllusb's Avatar
Ahhh gotcha. Everything on our 2011 is still stock, hence why I want just a little extra help in towing instead of buying a new truck. It's a 2011 Chevy Avalanche 5.3L Flex Fuel with the upgraded factory tow package ( Tranny Cooler, Brake Controller, Rear End.)
Old Jan 25, 2021 | 05:49 AM
mrcllusb's Avatar
Which turbo kit do you have?
Old Jan 25, 2021 | 06:34 AM
madmann26's Avatar
If you're telling me you can't find a stage 2 turbo kit, I'm going to tell you you're not looking hard enough.
There are 2 well known vendors on this site that make turbo kits for our trucks.
@kbracing96 and @TrickTurbo
Old Jan 25, 2021 | 07:04 AM
mrcllusb's Avatar
Since you stated I'm not looking hard enough, on either of their websites, do you see any mention of a Stage 2 kit? The answer is no. Do they offer kits, yes but I was looking specifically for a Stage 2 which neither website shows.
Old Jan 25, 2021 | 07:12 AM
madmann26's Avatar
A quick google of "TrickTurbo" yeilds the first hit link:
https://trickturbo.com/shop/ols/prod...b-kit-for-2011
"Stage 3" right off the bat.
Kyle's kits @kbracing96 - While he doesn't list a "stage" number, one could surmise that by the below information (on the site nonetheless) what a given "stage" would be:
$3200 for intercooled Borg Warner S366mm (up to 550hp),
$3600 for intercooled Borg Warner billet S369 (up to 650hp),
$4000 for Intercooled Borg Warner S475, T4 or T6 (up to 800hp)
$4400 for Intercooled Borg Warner S480, T4 or T6 (950hp+)
I would interpret that as "stage" 2-5.
The term "stage" is a catch phrase really. A WOW factor if you will. What you want to ask yourself is what HP level do I want or need for my given goal. Then go from there.
Old Jan 25, 2021 | 07:26 AM
mrcllusb's Avatar
Thank you for clarifying about the term "Stage." All I'm looking for is just a small bump in power when towing our 6,000lb travel trailer, since we travel cross country. The Avalanche is heavy enough as it is ya know.
