which spacer kit for tbss with mototrons
Old 03-24-2011, 03:48 AM
rhinosarge's Avatar
Default which spacer kit for tbss with mototrons
is this the right kit?
http://store.katechengines.com/fuel-...r-ls2-p16.aspx
ima be using the tbss intake
the mototron 60's are bigger then the stock ls2 injectors..
which spacer kit to i get?
and what connectors
Old 03-24-2011, 06:15 AM
Static54's Avatar
Connectors for those Injectors should be an EV1 to mini Delphi depending on what engine your running.
You wouldn't happen to know what dimensions those spacers are would ya? They look like parts of a Machine I build.
Old 03-24-2011, 06:37 AM
wkdivr's Avatar
Ummmm.................................maybe call Katech, and ask them? Or......................measure the o-ring to o-ring distance on the 2, and that's you spacer size.
Old 03-24-2011, 06:43 AM
Chavette's Avatar
The spacers that came with my blower were the difference between running the injectors that came with blower and LS2 Bosch. I would "guess" it would be the same, but I am sure someone on here could confirm that. The dimensions of these are 1/2" OD x .257" ID x 5/8" long. I bought a replacement plus spares through a fastener supply.
Old 03-24-2011, 07:21 AM
Mod with training wheels
smokeshow's Avatar
I got that exact same hardware at Ace for like $6...
Old 03-24-2011, 08:18 AM
Alpinestar's Avatar
I just told the place I ordered my injectors from what it was going on and they put the right o-rings on for me. Then just installed the injectors and measure the gap with a digital caliper and made my own spacers and got longer bolts from Lowes. You will also have to drill out the holes on the fuel rails that the bolts go through bc the taller height of the injector throws of the bolt alignment.
Old 03-24-2011, 02:16 PM
rhinosarge's Avatar
sounds good.. thats what ima do this weekend.. ill post some pics up..
TurboJohn6
11-08-2015 08:12 AM
GXPJAY
11-05-2015 06:49 AM
YenkoST
08-28-2015 01:42 PM
maxspeed05V
08-17-2015 08:41 PM
maxspeed05V
08-12-2015 06:29 PM
Quick Reply: which spacer kit for tbss with mototrons
