Soon to be Boosted
So I will sonn be buying a KBracing t70, t76 or a trick performance stage 3 for my 08 crew cab 4.8. I been reading the threads but its like rocket science to me lol. I guess my question is what is the best fuel pump and size injectors for my setup. This is a daily driven truck on rims, just want about 500rwhp. Any help would be greatly appreciated so I can start buying all the small stuff i need and then just get the turbo. Mods in sig. cam is a 215/222 on a 113LSA with .602/.604. Thnaks guys.
It flows more than the 255. It's what I plan on running, and MurderHeWrote is running it on his. It's part # 11142.
As 14psisupra said, around 65 lbs would be a good injector for you with your goals. I will be running corn fuel so I'm looking for 85 lbs or so.
I'm so close to having mine installed I can taste it, just waiting on a little bit of extra funds to buy the pump, injectors, exhaust wrap, and boost controller.
Might want to consider e85 since we have a few stations here in San Diego..But a 340 seems like the go to FI pump..
who installed your cam for you, Me and a GM tech do alot of side jobs..
finally another PT member from SD, lol. where were u at the races on friday? and are u going to the meet this weekend? matt from up north did the cam and justin tuned it.
thats pretty serious power for a 4.8 unless your foose. walbro will get you to 500rwhp, but might as well put the aero 340 for just a little more $. i run dephi 60 # injectors and only at 80% making over 500rwhp.
nonsense there are a bunch of guys here doing that, i just seen a guy make 539/579 with 24's on a crew cab. These GMT 900 4.8 are pretty bad *** built up. but thanks 340 it is its an aeromotive right? now im just researching any harnesses or anything i need to make it work with my stock fuel system.
