Something i noticed last night about my wastegate.
Old Dec 5, 2013 | 11:10 AM
  #21
chevrolet all the way's Avatar
it would eventually equal out pressure so you would make same boost pressure with or without the plug. The only difference is with the plug it may have slowed opening speed slightly causing a slightly quicker spool.
Old Dec 5, 2013 | 07:14 PM
  #22
slow67's Avatar
Gingervitis Addict
The AMS style controllers just shoot for a target PSI on top of the gate, it doesn't care what your motor is doing. It basically is creating a variable air spring.
In lower backpressure setups, 1psi on the gate will add 1psi over what the spring does.
Old Dec 5, 2013 | 07:48 PM
  #23
Byrdman11's Avatar
Guys I use on my cust car a simple setup. Small compressor, switch to control compressor, and a small tank with regulator.. I got the idea from a air horn setup and a air shifter.
Old Dec 17, 2013 | 06:52 PM
  #24
BlackGMC's Avatar
Resident Retard
So after removing that plug my truck only makes 5psi. But it holds that 5psi with no creep. It is like it hits a wall! Time to get off my butt and finish the boost controller install.
Old Dec 17, 2013 | 06:58 PM
  #25
smokeshow's Avatar
Mod with training wheels
What was it before?
Old Dec 17, 2013 | 07:01 PM
  #26
BlackGMC's Avatar
Resident Retard
Around 8-9.
Old Dec 17, 2013 | 07:08 PM
  #27
smokeshow's Avatar
It was sealed up pretty well then. That's a decent jump.
Old Dec 17, 2013 | 07:14 PM
  #28
BlackGMC's Avatar
Resident Retard
Yeah 5psi is rather lame thou....
RustyD
May 23, 2016 07:04 PM
bearden86
26
Nov 15, 2015 03:58 PM
Chewy07
Nov 14, 2015 09:46 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
