Someone needs to try one of these turbos
Old Sep 29, 2006 | 05:19 PM
thunder550's Avatar
High on diesel fumes
Default Someone needs to try one of these turbos
6000 hp twin turbocharged locomotive engine.
some specs:
16 cylinders, 1010 cu/in displacement each
6300 bhp @ 1000 rpm
33,000 ft/lbs torque
Dual 14" exhaust
750 gallons oil capacity
55 psi max air pressure per turbo
dual split aftercoolers
cost: $750,000
Old Sep 29, 2006 | 05:31 PM
vanillagorilla's Avatar
I had a pair of those in a Nova once. They were kind of laggy on my 355, but once they spooled it was fun to drive.
Old Sep 29, 2006 | 05:34 PM
CHEVRACER83's Avatar
some specs:
6300 bhp @ 1000 rpm
Dual 14" exhaust
cost: $750,000
Wonder is that would fit under a cowl hood?
Would i have to replace my 60e to run that?
Old Sep 29, 2006 | 05:37 PM
No, it bolts right up, you just need a custom flexplate.
Old Sep 29, 2006 | 05:56 PM
HAHA!!!!!
im guessing flt level 5 to handle this??
Vince?? what do you got for this??? we need you to come through...
not to mention it would need some long gears to make that thing get any speed
Old Sep 29, 2006 | 06:00 PM
Looks perfect for a mid-engine Suburban.I guess I could mount the 150 gal fuel tank under the hood,but what do I run for a transaxle? Sounds like a killer 2 seater SUV and all for just under $1,000,000.00.Where's Jay Leno when you when you need him.
Old Sep 29, 2006 | 06:03 PM
Give jay some time...... or better yet what about a bike??
Old Sep 29, 2006 | 08:31 PM
litreddevil's Avatar
Banned
i think i will look into this one for the truck 1000hp should be easy and would not have to turn it to high
Old Sep 29, 2006 | 08:43 PM
Stoichiometric's Avatar
If you replace the rod bolts you can take it to 7000HP.
Old Sep 30, 2006 | 11:42 AM
Mort's Avatar
Cool
I wanted mine painted some other colors and the turbos polished.
