So it begins.... A rebirth or massive cluster??
Old May 27, 2015 | 09:43 AM
  #21
kbracing96's Avatar
Originally Posted by thunder550
Good choice, do it right or do it twice
Our buddy Daryl's company motto... "We do it nice cus we do it twice!"
Old May 27, 2015 | 09:51 AM
  #22
Vortec350ss's Avatar
I like that black pulley!
Step up man!! a 3.4 with a stock balancer is weak!!! The more you pulley down the more responsive it will seem down low. Its not like a turbo where when you change the waste gate it enables you to build more... with a blower its more at all throttle levels. It will hit boost quicker and easier.
Old May 27, 2015 | 09:54 AM
  #23
BlackGMC's Avatar
Resident Retard
It was on sale that is why i bought it. I have my eye on a Innovators West 8rib one, but i gotta get a baseline boost number first before i go spending more
Old May 27, 2015 | 12:43 PM
  #24
Atomic's Avatar
I have a gauge for that
If thats the case then mine with a 2.8 and OD crank pulley should be fun!
Old May 27, 2015 | 12:45 PM
  #25
It is... its basically the same combo I run now with my 1900.
Old May 27, 2015 | 12:47 PM
  #26
Atomic's Avatar
So if I ever get a good way to machine the spacer I want to make then I am going to drill it and tap it for nitrous fittings. Semi-direct port under the blower.
Old May 27, 2015 | 01:23 PM
  #27
1FastBrick's Avatar
Custm2500's Rude Friend
Spacer machining???
What kind of material???
Old May 27, 2015 | 01:24 PM
  #28
Why not just run 2 fogger bars rather than semi direct port.
Old May 27, 2015 | 01:35 PM
  #29
Atomic's Avatar
Material is just normal aluminum, maybe 6061. I havent really looked into it that hard, just have an idea.
My issue with machining will be getting the thickness I want (between 1/2" and 1" probably) at a resonable cost, and some 3d features I want milled like a 0.1" groove for a gasket, etc. Still working on getting a first cut from 1/8th steel to see if my measurements are good before I am looking to have it cut out of something thick. 1/8th steel is $10 whereas 1/2" aluminum is $100.
Old May 27, 2015 | 01:46 PM
  #30
1FastBrick's Avatar
What Blower? why not call and have them and see if they will give you the bolt pattern.
